Just swapped an 87 'i' harness into my car to use in an 'i' head swap and I am trying to start the car and getting no spark and no fuel, by no fuel I mean the fuel pump isn't even turning on. The coil is fine, plugs are fine, injectors are fine, and CPS is fine. I should probably mention I'm using eta plug wires not 'i' plug wires, i know the 'i's have a pickup sensor on plug 6 but i heard its not really necessary. I did have to make an adapter to use the 87 harness in my 85 car by splicing the two connectors, other than that everything should be working properly.
no spark, no fuel
Tags: None
If the fuel pump isn't turnig on maybe you have he CPS plug and the other plug next to it switched around I forget what it's called. I wasn't getting my fuel pump to turn on when I rebuilt the head on my car. There was also a fuse in the trunk next to the battery that was blown out on my car.Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot you -
thats actually exactly what it was. right after posting this (on every forum none the less) i figured out it was in the wrong plug.. lolIf the fuel pump isn't turnig on maybe you have he CPS plug and the other plug next to it switched around I forget what it's called. I wasn't getting my fuel pump to turn on when I rebuilt the head on my car. There was also a fuse in the trunk next to the battery that was blown out on my car.-AlexComment
