Changing out the bottom end in a 2.7 eta
    So as some of you may know, I just bought a bunch of E30 parts. Well Ive figured out what most of the engine parts are, and Im trying to figure out my options as far as putting the parts to use. I have:
    2.7 Eta
    stripped and waiting to get hot dipped
    M50 cast crankshaft with a 75mm stroke with front crank seal sleeve
    S50 135mm forged connecting rods
    Metric Mechanic HiFlo ST Sport Small 6 Cylinder Head
    Complete 325i intake
    325i motronic 173 DME
    325i wiring harness
    I know the standard stroke of the 2.7 is 81mm, and the stock rods 130mm long, and in a 2.5, the crank stroke is 75mm with rods that are 135mm long. Any idea as far as what the previos owner was going for with the parts he aquired was he trying to go to a 2.5 from the 2.7? Is there anything I can do with the new rods and crank or should i be looking at a different route? My ultimate goal with this engine is to go the forced induction route. Thanks for any help.
    1987 Delphin 325IS
    LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
    Build Thread
    1993 alpine 2 325IC
    •Ground control coilovers•16" BBS RS• momo woodgrain
