ECU/Glovebox wires?
  • Andy348
    • Sep 2009
    • 688
    ECU/Glovebox wires?
    I'm wiring up an 87 M20B25 in a 86 eta chasis.
    Where do these wires go?
    Also, theres two that are in the engine bay close to the right shock tower. Any idea where those go?
    Tahnks.
    Uploaded with ImageShack.us
  • The Humjet
    • Jun 2010
    • 528
    I think the the two wires in the first photo is the earth connection and is bolted onto the shock tower with the ignition coil bracket bolts.
    Second picture I think (I could be wrong) is supposed to connect to the ecu but they're only for automatic transmissions so leave them out
    Hopefully somebody can chime in and fix my errors if i'm wrong. But the top photo looks kinda familiar when I was helping my friend do an m30 swap while using the e30 325i wiring harness
    • Andy348
      • Sep 2009
      • 688
      More questions!
      I can't find where the second brake booster hose goes, as well as the two hoses off the intake manifold and this random fuse box wire.
      Thanks for the help Humjet
      • blueapplesoda
        • Dec 2005
        • 1904
        pic1 right side: intake boot
        pic1 center: coolant IO, to the thermostat housing and the back of the block near cyl 6 in the intake side.
        pic1 left side: ICV -> intake boot
        pic2: cmon .... its red, and its a wire...a fat wire....battery positive terminal. That little plastic flap next to the engine harness hole
        pic3: to check valve under the TB
        next time go to the yard and look stop being lazy or search for pics google is your friend
