I'm having problems with my car idling it quits if i don't hold the gas down for at least 1k rpm for five minutes. After this it idles fine the old ICV is hooked up but it is broken. If i hook the new one up it idles at 2k rpm. I found the below article
http://www.rickk.net/i/drive/bmw-e30-325i-motronic-10-information/
And i got to hear
"If the valve seems to be okay, turn on the ignition measure the current from the ecu to the valve at the connector:
And i determined that the valve Conector that connects to the ICV does not have any Volts at all.
So does this mean my ECU/DME is bad? is there a way to check ECU pin 33 and 34?
Please advise
I did some more research and found out that it could be the Idle idle control unit. I can't find one on the net for my car only the 325e. So I guess I don't have one, which leads me to beleive that it is the DME.
I have a DME for a E36 can I swap the chips and use it in my car?
The dme that I have for a e36 has part numbe 0261200402 and it has A brownish Red sticker
And i got to hear
- between the inner pin and ground there should be battery voltage
- between any outer pin and the inner pin there should be around 10V
Please advise
