So I am looking for some answers.....
  • tj_patlan_91
    • Apr 2011
    • 39
    My e is faster than stock. I just wanna know what is altered from stock and I am trying to narrow it down. To start off, it has a ram air intake and I have the stock intake manifolds on my porch. So I am assuming they are upgraded. I just took the ecu out to check if it was chipped. So I need some help.
    Here is the motor. Chime in if you notice anything weird.
    Here is the chip that is in there. Is this stock?
  • Sagaris
    • Sep 2009
    • 2243
    I have never heard of an ACS chip for a 325e. It might just be an ebay clone with the ACS logo put on it, I would be interested to know if it was real. The chip says it is for an 027 ECU so it hasn't been converted to a "327i". They might have done some head work and they may have changed the differential. Did you run the 1/4 mile? what are you using as a metric to compare it to stock?
    • Sagaris
      • Sep 2009
      • 2243
      Wait wait wait, is that a yellow dipstick!?!? I think I just found your big power gain!
        • 37832
        Other than spray paint mods the engine appears stock. A chip does help the 325e a lot though. As mentioned it's most likely an eBay copy. Since it's already in there I say keep it in there! Another amazing upgrade for the Eta cars is going to a 3.25 LSD.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • tj_patlan_91
          • Apr 2011
          • 39
          The yellow dipstick and this.
          But I will make a video tonight of it accelerating. Someone with a stock e drove my car the other night and I asked him how it compared to his and he said my car pulls alot harder. I already thought it was kinda peppy, but this confirmed it.
          The reason I looked to see if it had a chip was because I was planning on getting a MarkD. I am going to see if higher octane fuel will do anything since I have never used any. An ebay chip would still require higher octane correct?
          • urbancynic
            • Dec 2008
            • 384
            Every chip I've seen has required 91 octane.
            You most likely have an ebay chip in there, but if it works leave it alone.
            The chip makes a night/day difference in an eta, so that could very well be the only real mod done. Hard to tell without tearing apart the motor.
            • tj_patlan_91
              • Apr 2011
              • 39
              Has the car been hurt in anyway by me only using 87 octane?
              • Sagaris
                • Sep 2009
                • 2243
                Only if you hear the engine pinging.
                • tj_patlan_91
                  • Apr 2011
                  • 39
                  It doesn't make any abnormal sounds. Just a little tick of the head. I will put some 91 in before I make the vids.
                  • matt0300
                    • 549
                    how much gain are u getting off the painted valve cover? i was expecting around 17hp but it was only showing 13hp on the dyno. was wondering if u were having the same problem.
                      • 37832
                      Nah, Eta engines are the spawn of Jesus.
                      Just do 91 starting now.
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • rodpaine
                        • 33
                        Snip... Here is the chip that is in there. Is this stock?
                        The chip is bogus and probably a clone of an Auto Authority chip, which I also bought a number of years ago via eBay and had Mark D'Sylva determine what it was, since ACS NEVER produced or sold such a chip, per my discussion with them. The D'Sylva chip in my '83 528e with an '027' ECU produces 15.8 RWHP additional on a dyno. The stock cold air system is better than the system you have, as many people have tested both over the years. Has the rear end been swapped? I changed mine from its stock 2.93 to a 3.46 and it made a big improvement in driving performance. Check out my web site for further info about all these changes.
                        -Rod
                        Rod's 528e support web site
                        A car can be restored many times. It is original only once.
                        • skirkpat
                          • Jun 2011
                          • 22
                          I had the same question?? I just bought this off CL from an older lady, one owner...she must have lived close to work, she said it was usually only driven 1/4 mile at a time.
                          This is my first BMW, any help wouold be appreciated.
                          • PNWDan
                            • Feb 2011
                            • 1326
                            1987 Alpinweiß 325is
                            Like the PNW E30 Local Crew Facebook page
                            • Sagaris
                              • Sep 2009
                              • 2243
                              That power steering reservoir is from an E30 which is what makes your car awesome.
