raising revs?????
  • Gordon1987
    • Feb 2011
    • 76
    raising revs?????
    How can i raise my rev limit from 5000 to 7000..... i have an E computer 027
  • davem
    • Jun 2010
    • 705
    u can't
    • MTechnikII
      • Jun 2007
      • 83
      you might / will bend a/couple of valve, for higher rev you need stiffer valve springs plus electronics that can control the fuel and ignition at that RPM
      Henry
      • Myster-E
        Performance
        • 552
        Henry
        You mean valve float?
        1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
        Visit www.BimmerHeads.com for all of your 12 valve needs!
        • blocke
          • 1305
          Buy an "I"
          Parts Wanted
          The Never-ending Resto Mod
          • lolcantturn
            • 4588
            Buy "How to search for Dummies"
            Originally posted by TSI
            OEM+
            • blindwOw
              • 124
              do this
              '87 Zinno 325e
              • matt0300
                • 549
                megasquirt
                  • 37833
                  Henry
                  The Eta cylinder head physically CAN NOT rev that high. Nothing will bend or break, it just won't do it.
                  Originally posted by matt0300
                  megasquirt
                  Not even Megasquirt can make an Eta engine rev that high. Super awesome suggestion though.
                  Grover Beach, California
                  BimmerHeads.com
                  • Gordon1987
                    • Feb 2011
                    • 76
                    its an I head i just have the e computer. im trying to avoid the I computer
                    • Gruelius
                      • Oct 2009
                      • 298
                      put in a 4cyl cluster.
                      RIP 84 323i coupe 5spd w/ 14psi
                      89' 318i
                        • 37833
                        The ONLY way to make it do what you want is to swap an i harness and computer. You'll also want the i throttle body, intake manifold, and injectors if you don't have them. Along with the i AFM and crank sensor.
                        Not sure why you're "trying to avoid the i computer. Swapping the harness and all other parts I mentioned above can be done in one day easily.
                        BimmerHeads.com
                        • matt0300
                          • 549
                          How different are the harnesses?
                            • 37833
                            Completely.
                            BimmerHeads.com
                            • acolella76
                              • 2950
                              very different, very easy swap though. It took me about 20 minutes and 10 of that was drilling out that damn hole in the firewall
                              -Alex
