running rich ? blowing black smoke
  • byza213
    • Feb 2011
    • 334
    hi guys
    Please lead me toward what is causing this.
    something to do with fuel im guessing
    the car almost stalls and sometimes does when its cold and i put my foot flat on the clutch.
    seems to run fine when im driving and warm but the fuel ecomony is crap,
    fumes have also been staining my freshly painted rear bumper :(
    1986 325e ( baur project)
    1986 535i e28
    1990 325i touring (sold)
    1990 mk2 golf (sold)
    1983 e28 525 (sold)
    love my old girls
  • Sagaris
    • Sep 2009
    • 2243
    Check the FPR vac. line for fuel there should not be any in there obviously. If there is, replace the FPR.
    Check fuel pressure. If high, replace FPR.
    If still high after replacement, check for a clogged fuel return line.
    Replace ECU.
    • matt0300
      • 549
      Sounds like o2 maybe and that black smoke sounds like ur cat melting
      • Sagaris
        • Sep 2009
        • 2243
        When in the history of man has a catalytic converter ever caused black smoke to pour out of the exhaust ?
        • matt0300
          • 549
          Someones never had launch control
          • matt0300
            • 549
            I could be wrong. But black smoke was coming from my friends car when we got launch control set up. The black smoke was from melting his cat.
            • Ryann
              • 3350
              You may have a shorted harness causing some of your injectors to stay open all of the time.
              • matt0300
                • 549
                http://share.ovi.com/media/jaxx75.Pu...a/jaxx75.10116 sagaris, I guess I just made history. Ur an engineer right? So why is a 19 year old proving u wrong? Now could u stop being an asshole?
                • matt0300
                  • 549
                  And check ur coolant temp sensor.
                  • Sagaris
                    • Sep 2009
                    • 2243
                    Link doesn't work.
                    Yes I am an engineer, which doesn't mean that I am a know-it-all. It simply means that I make a living designing machine parts. Checking the coolant temperature sensor was a good suggestion, but I don't agree at all with the cat. convertor suggestion.
                    As far as your friend's car pouring out smoke. The launch control most likely allowed a lot of unburned fuel into the cat., which caused it to get hot and ruined it by melting the substrate The black smoke is from the unburned fuel that caused the cat. to fail, not from the cat. itself.
                    • sweet6e30
                      • Feb 2011
                      • 531
                      might want to put a new set of spark plugs after all this is said and done
                      my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                      • M-technik-3
                        • 18946
                        Ditto on this for a nice quick ohm out. If in spec check other simply items.
                        As far as the name calling, that just shows your maturity level.
                        • matt0300
                          • 549
                          It is from the unburnt fuel exploding in the downpipe or cat. My guess is that the plugs are fouled out so he has a lot of unburnt fuel doing the samething to his cat. My friends car doesn't have black smoke anymore and his cat is ruined. I'm just putting 2 and 2 together.
                          • byza213
                            • Feb 2011
                            • 334
                            thanks all , i will be looking into all of the above and post the out come of this,
                            i just had manifold gaskets changed with new studs , new flange gasket , exhaust leak issue gone.
                            need her running good!!!
                            1986 535i e28
                            1983 e28 525 (sold)
                            love my old girls
                            • Cabriolet
                              • 9620
                              My money is on a bad(dying) o2 sensor that is causing the car to run too rich. check you AFM, using the Bentley manual's test. Check for vacuum leaks. last option is DME is shot.
                              (black smoke issue) many times with these older engines. we get oil leaks. if it blows smoke continuously you have bad cylinder rings if it blows really bad after just idle then acceleration its valve stem oil leaks. wipe down the inside of the tail pipe, if oil separates out of the carbon/ash. you have 1 of the 2 issues i mentioned.
                              Much wow
                              I hate 4 doors
