No spark/fuel after b25 swap
  • Andy348
    • Sep 2009
    • 688
    The car cranks quite willingly yet doesn't get any spark or fuel. Now I know it can either be the CPS, main relay/fusible link, or a bad ECU. I'm concerned that it might be the power/ground for the ecu, but I'm not sure how to check for power there. Any suggestions?
    I also have two stray wires coming off of my relays, I think one is from the main relay and one from the fuel pump. One is red and the other one black. Once I recharge the battery I'll test them for power/ground, but does anyone have an idea where these might go?
    Lastly, I messed up the wiring on the passenger side firewall and had power running through the grounds. I finally changed that, but is there a chance that my harness is fried?
    Thanks
  • Andy348
    • Sep 2009
    • 688
    fml. The starter seems to only work intermittently. It'll crank over twice, and then it won't work for awhile. The battery is pretty much fully charged too.
