What size electric fan will fit? (M20)
  • ROLLingKING
    • Apr 2011
    • 1169
    Ive got a 87 325is and I want to take out the clutch fan and wire up an electric fan in its place.
    what size fan will fit and is it a puller or pusher fan?? i think it pushes the air back at the motor but im not certain. If anyone has done this conversion let me know whats worked for you. id like to order the fan friday afternoon if i can get some suggestions
    Thanks
    m20 is plenty. im simply a drifter.
    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
    You can fit a 16" SPAL puller fan rated at 2300CFM between the radiator and engine.
      • 37834
      The type of car doesn't decide on puller or pusher. Pusher goes in front of the radiator, puller goes behind.
      Grover Beach, California
      BimmerHeads.com
      • ROLLingKING
        • Apr 2011
        • 1169
        word..thanks! does this look like a decent fan?
        http://cgi.ebay.com/ebaymotors/WBK75...05193313403597
        • MaksV
          • 1042
          I got the Spall and relay kit from Bimmerworld. I would talk to them.
          CHEAP REBUILT INJECTORS
          Need Quality Brakes? BimmerBrakes has it!
          For anything Else go with BluntTech!
            Unless you are going to install the fan in a full shroud you need a 16" fan.
            • CHIF8008
              • 3447
              still make a shroud if you want good air flow- no matter what the size of the fan is
              -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
              -The Beauty in the Tragedy-
              MECHANIC SMASH!!- (you all know you do it)
              Got Drop?? ;-)
              But of course
              E30s are know to be notoriously really really really ridiculously good looking
                That is correct, a shroud will will improve the effectiveness of the fan. My point was that if you drop back to a 14" fan the shroud becomes essential.
