I am at the end of my rope chasing this leak. Appreciate any direction you guys can give.
Background: Pulled my transmission a few weeks back to replace a leaky input shaft seal. I did not touch anything on the engine side. Clutch, PP and FW stayed in place.
2 days after fixing the input shaft seal, oil starts dripping from inside the bell housing. At first it was just 1-2 drops. After about 100 miles of driving, my clutch started slipping at 4k rpm. So I assumed the rear main seal (replaced just 1 year ago) had let go.
Dropped the tranny again this past weekend, examined rear main seal. It looked fine, back of the block was clean from the head down. I cant see any cause for the leak. Just to be safe, I replaced the rear main seal, the cover gasket, clutch disk and pilot bearing. Put everything back together.
Drive to work Monday (100 miles round trip), car was fine. Park car in driveway and let it sit for 4 hours. Came back to check under car, and it looked like the BP oil spill in my driveway. HUGE oil slick. Oil is dripping out from inside bell housing again.
WHAT THE FUCK? I'm stumped on where it's coming from. The only thing I have noticed is that it looks like my car has the classic head gasket oil leak at the rear cylinder. Could this be running down inside bell housing? There was no oil trail coming from top of engine.
This all occurred after removing tranny. I dont know what I could have done to cause this when I didn't touch the engine side of things the first time around.
