No start on hot days
  • Cabriolet
    • 9620
    My friend has a 1990 325i. And on hot days (90F+) he has no crank.
    changed all relays.
    to get the car to start he jumps a line from the battery to pin 11 on the diagnostic port on the engine.
    then the car starts. or we can push start it, to get it to run.
    do you guys have any ideas of whats going on there?
    we are thinking ignition or the starter interrupt. thoughts on testing this?
    Much wow
    I hate 4 doors
  • bmwstephen
    • 2463
    it sounds like the starter but that could only be if you hear nothing engaging when turning the key all the way. when i first bought my car it would not crank up immediately after the first drive. I would have to wait an hour or so for the engine bay to cool off before it starts again
    • MaksV
      • 1042
      I sometimes have this issue too. Changed batteries - issue dissappeared.
      CHEAP REBUILT INJECTORS
      Need Quality Brakes? BimmerBrakes has it!
      For anything Else go with BluntTech!
      • matt0300
        • 549
        What about coolant temp sensor?
        • rares
          • 730
          check ignition coil and check valve in the fuel pump. my bet is it is one of those.
            If the engine won't crank (i.e. turn over) by the key yet will by the diag connector, the ignition switch or wiring from the switch to the starter are the suspects.
            • Cabriolet
              • 9620
              thx guys for all the info. we'll be tearing into his car soon.
              Much wow
              I hate 4 doors
              • matt0300
                • 549
                Sorry the coolant temp sensor wouldn't not make it start but everyone else's suggestions are good.
