Non Idle idle?
  • kcoelhoe30
    • Jun 2011
    • 219
    Non Idle idle?
    Ive been working on my project car and finally got it back togather today but when i started the car i realised a difference in the idle, it is now at 1500rpms idle and its not exactly "idle" its reving up and down constantly and idk what it is...
    Any help?
  • ttrousdell
    • Nov 2009
    • 1770
    All connections tight and in the right spot? I experienced a crazy idle after I forgot to connect my maf sensor after motor work. Probably something stupid you forgot. I doubt it would idle that high if its a vac leak and it the leak was that big the car wouldn't stay running
    The Build:
    • ckarsonkidd
      • Jul 2011
      • 446
      have you checked your vacuum? maybe its having a problem breathing
      • kcoelhoe30
        • Jun 2011
        • 219
        originally i forgot to tightewn a few clamps when i put the intake back on but i tightened em and it helped but sitll not right
        • rjfurlan
          • Jul 2011
          • 15
          My was at 1100 and would jump to 2000 when I turned on the AC. I traced it to a bad throttle position switch. Also check out your idle control valve.
