So this has been an ongoing thing with my car: Its failing Horribly on NO(x).
im getting readings of over 1800+ labeling my car as a gross polluter. This is what i have had changed since ive owned the vehicle:
All coolant hoses
Radiator
Thermostat housing
Water pump
Timing belt + Tensioner
Thermostat
All Vacuum lines
Spark Plugs
Replaced Catalytic converter
Brake booster (had a huge vacuum leak)
cleaned ICV
Valve Adjustment
Replaced fuel tank
Replaced Fuel Filter
Replaced fuel lines
Things that im thinking that are causing my NO(X)
Engine running way lean (dont know why though)
Advanced timing.. just a little bit?
the engine sounds like it has a tiny 1 cyclinder misfire...
any help is GREATLY appreciated, my other numbers for the CA smog are great all WELL under all readings EXCEPT NO(X)
help mee!!!!
All coolant hoses
Radiator
Thermostat housing
Water pump
Thermostat
All Vacuum lines
Spark Plugs
cleaned ICV
Valve Adjustment
Replaced fuel tank
Replaced fuel lines
help mee!!!!
