Fuel system cleaner
  • harold30
    • Jul 2011
    • 180
    Fuel system cleaner
    Hi guys,
    As always i needed some suggestions. When i took my car out of the shop i fueled it to full tank and drove around the city. After a while i found out the fuel gauge jumps from full to half and back. Could it be a bad fuel sending unit? I also think of trying out Redline ST-1 Complete Fuel System Cleaner since i have 1 unused bottle. Does it hurt the fuel system? I just had my injectors cleaned and rebuild but i want to try cheap solution first. What do you think? Thanks in advance.
  • harold30
    • Jul 2011
    • 180
    Any thoughts?
    • ak-
      • 12422
      Bad sending unit, or the ground nut behind the gauge has come loose.
      My guess is the sending unit, it's common.
      1991 325iS turbo
      • Tree25
        • 118
        Does the ground nut on the Temp guage commonly come loose as well?
        • E30_fiend
          • Apr 2006
          • 7348
          Any ground CAN come loose. Just do yourself a favor and take a look at the nuts on the gauges. Tighten them if needed.
          My guess is a sender. The ground is a possibility too but it causes different symptoms than that.
          Taylor
          • airkhin
            • 593
            my temp gauge has had a mind of its own as well, with similar problems, loves to jump around all over... is there a sending unit or something else that commonly goes bad with the temp gauge? or should i just replace the gauge and call it a day?
            (i recently swapped out the si boards thinking that was the problem, but it still exists, the grounding nut was tight if memory serves me well...)
            • cbouchez
              • May 2007
              • 2789
              ^^ I'm in the same boat.
              Follow my IG @bouchezphotography
