M20B25 Head mods
  • Tree25
    • 118
    M20B25 Head mods
    I posted earlier in the week about snaping a rocker arm in my m20. Since i do have the head out of the car id like do splurge a bit extra since i dont plan on taking the head off again.
    Looking at IE heavy duty Rocker arms, New Rocker shafts, and a Regrind 272 cam...All of this with the gaskets, belt, pump, tensioner etc. Im already looking at close to a G before sending the head to the machinde shop.
    This is my first rebuild...Pros/Cons?
  • Jafxod
    • May 2011
    • 1301
    Then you are 500 away from an S52. Be wise ;)
    • Tree25
      • 118
      All parts needed, your telling me I can have an s52 for 1500?
      • ScHpAnKy
        • 1573
        I don't see why not, as long as you can source an oil pan for cheap.
        91 318i | 87 535iS
        • acolella76
          • 2950
          MAYBE you can buy the engine for that much, but it won't even touch the car for $1500
          -Alex
          • Teaguer
            • Sep 2004
            • 6167
            Don't waste $$ on all that unnecessary shit.
            Buy the cam and rocker that needs replacing and valve guide seals. Thats it.
            Then spend the extra $$ on some long tube headers.
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              If you do the regrind, you will need oversized eccentrics as well. Just buy the billet cam. Heavy duty rockers aren't needed unless you are constantly living over 7000 rpms. What are you wanting to do with this engine, what are you currently running as far as software/ mods? You could go bigger valves as well to help the head inhale/ exhale better.
              Yours truly,
              Rich
              you kids get off my lawn.....
              • Bearmw
                • 1323
                stock head rebuild, ltw flywheel, and 3.90 small lsd= more bang for the buck I think.
                • Myster-E
                  Performance
                  • 552
                  You shouldn't need bigger eccentrics for a 272 cam. I have run several reground cams that were much wilder than than that with no issues with stock eccentrics.
                  1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
                  Visit www.BimmerHeads.com for all of your 12 valve needs!
                  • lolcantturn
                    • 4588
                    Undoubtedly.
                    You're right, it won't. It'll probably be a hair under $1480.
                    Originally posted by TSI
                    OEM+
                    • delatlanta1281
                      Dart Master
                      • Mar 2006
                      • 10317
                      Huh, interesting, I didn't know that.
                      Yours truly,
                      Rich
                      • delatlanta1281
                        Dart Master
                        • Mar 2006
                        • 10317
                        You planning on replacing anything on that 1500 dollar motor, or you just going to shove it in there and hope it gets you to work in the morning?
                        Yours truly,
                        Rich
                        • acolella76
                          • 2950
                          You probably forgot that this is r3v when you posted that.
                          -Alex
                          • delatlanta1281
                            Dart Master
                            • Mar 2006
                            • 10317
                            Just trying to change the world.
                            Yours truly,
                            Rich
                            • acolella76
                              • 2950
                              I really want to know how this guy can swap an S52 into an E30 for less than $1500
                              -Alex
