Get my fan clutch off PLEASE.
  • London
    • 532
    EDIT:
    Hey so I've tried and tried and am losing my mind with this damn fan clutch. Anyone in SD willing to help me get this fucker off? I will give you beer money or something haha. I'm seriously ready to just kill it. I've gotten it off plenty of times before but I just cant get it by myself. Let me know if anyone wants/can lend me a hand some time.
  • ttrousdell
    • Nov 2009
    • 1770
    Its reverse thread so you turn it to the right when looking at it from the front of the car. They sell a special tool for this but if your cheap like me you wedge a screwdriver in between the small 10mm water pump pulley bolts to keep it still then hit the 32mm wrench with a hammer
    The Build:
    • London
      • 532
      Yeah I knew it was reverse thread. I just wasn't overly sure how to go about doing it. Just tricky cause I don't have a lot of area to work, cant even take the hood off so its just kinda awkward haha. I'll try your method though.
      • ttrousdell
        • Nov 2009
        • 1770
        yea it helps if the screwdriver is square and you back out the 10mm bolts a hair so there is more room for the screwdriver to rest on
        The Build:
        • London
          • 532
          Edited this bitch.
          • bmwm42
            • 6300
            A big ass 32mm or 1 1/4 in wrench plus a chain strap should do the trick
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
            • E30_fiend
              • Apr 2006
              • 7348
              Leverage is your friend. I take it you are probably using a crecent wrench or the like. If you can get it on there, get a pipe on the other end of the wrench as leverage. Make sure the waterpump pulley doesn't spin. I find it easier to put a pair of vice grips on the pulley and spin it till the pliers are resting on something. That way the pulley won't move.
              Good luck. And remember, you should be turning the wrench toward the drivers side of the car.
              Taylor
              • London
                • 532
                Yeah I know its a reverse thread and what not. Just I cant keep that damn piece on the pulley to not turn. Nothing I try is working to keep it still. I've been using a 32mm slim bicycle wrench thing. I just can't keep the damn thing to stay so I can unscrew the clutch
                • bmwm42
                  • 6300
                  Rent clutch fan tool ie big slim wrench that will fit over the bolts
                  • CHIF8008
                    • 3447
                    needs a good whack. then get an electric fan as your replacement and never have this problem. (plus the electric fan is slimmer/ cheaper and wont go out like a clutch fan)
                    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                    -The Beauty in the Tragedy-
                    MECHANIC SMASH!!- (you all know you do it)
                    Got Drop?? ;-)
                    But of course
                    E30s are know to be notoriously really really really ridiculously good looking
                    • London
                      • 532
                      I've always heard that the swapping to the electric setup is far more expensive than using the fan clutch...
                      • London
                        • 532
                        Where should I go to do that?
                        • bmwm42
                          • 6300
                          Autozone etc your local autoparts store
                          • CHIF8008
                            • 3447
                            hoW much will a new fan clutch be? $35?
                            you can get an electric one for basically the same price as a new clutch. search ebay and any other sight.
                            Got Drop?? ;-)
                            But of course
                              • 37833
                              A good electric fan is $60-$100. You're also need a mounting kit at $15. After that, you'll ideally want to run a fan controller which is about $25.
                              Stock fan clutch is idea IMHO.
                              Grover Beach, California
                              BimmerHeads.com
