OOOOOOOOKKK so i replaced the external....the external is getting fuel as i tried it and put the hose from the external into a jug and it pumped a decent amount into it..so my next guess is either a FPR or Vapor lock anything else I should be checking?
*Back story...*
Car was extremely low on fuel but i thought i could make it to the nearest gas station and she decided to cut out about 300 yards away and had to push it....get to the station put in about 15 bucks in and she started right up....But even when i got it back on, the throttle was not responsive at all as there was a hesitation if i would try and rev the engine..finally after about a min or two i tried to rev it again and then it cut out..and after that it would crank and crank but no start...not even a hint of starting... and i checked the pump and there was no fuel getting to the pump at all so i replaced it (today) after I figured there would be a hiccup signaling fuel was getting to the engine but nothing before or after the pump replacement...so.. back to square one....
I really need this car so any help would be great...
*Back story...*
