#19 Injector Queation
  • mccor023
    • Jul 2011
    • 683
    Ok so I know 19lb injectors are known for being noisy,
    But does anyone know of certain ones are less noisy than others?
    I have yellow tops now, I like the response and performance, but boy are they loud!!!
    Any help is great thanks.
    I love that people ask stupid questions so I dont have.
  • blocke
    • 1305
    I don't think it has anything to do with size or flow rate. I think its just inherent of the M20 and the injector styles used. My stock, 17.5 lb, and now my 19.5 yellow tops all sounded the same.
    Parts Wanted
    The Never-ending Resto Mod
    • E30_fiend
      • Apr 2006
      • 7348
      all injectors are going to make the clicking noise. Maybe now that you have that idea in your head, you were just listening closer for the tick. It could also be your valves clacking. My stock, 17.5 and two styles of 19lb injectors all made the same amount of noise.
      Taylor
      • mccor023
        • Jul 2011
        • 683
        Well i just had my valves adjusted, and we checked th twice bc my buddy who helped thought it was very loud, and he was running stock injectors in his m20.
        If its just going to be loud ao be it, still worth the performance. Just sad that i cant creep up on people anymore.
        Guess my stalking days are over.
        • E30_fiend
          • Apr 2006
          • 7348
          get loud exhaust or turn your stereo up. Problem solved
          • Luciano36
            • Jul 2011
            • 221
            I was looking for a thread on how to replace injectors and I found this recent thread on bimmerforums:
            This member claims that the 19lb injectors he got are significantly less noisy than the "old ones" he had before.
            Luciano
            Glacier blue metallic 1991 325ic
            • immajackuup
              • Dec 2010
              • 1132
              Luciano
              I think those injectors won't fit correctly.
              • mccor023
                • Jul 2011
                • 683
                Interesting, i dont know bout those, but they do look different than mine. I need cross refetence part numbers.
                  • 37829
                  They will fit perfectly.
                  A stock M20 DOES NOT NEED 19lb injectors though people.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • mccor023
                    • Jul 2011
                    • 683
                    I dont need a lot of things that i have or get.
                    I got 19 lb injectors bc of that is what was recommended w yhe mark d chip.
                    • mccor023
                      • Jul 2011
                      • 683
                      Sorry if my last post came off as "dickish" didn't mean too.
                      I'm going to order those other injectors and just do a comparison for kicks and giggles.
                      • James Crivellone
                        Head Janitor
                        • 6303
                        Chipped I've seen stock M20s start to lean out up high
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          that's how they make their power. 110% duty cycle... lol
                          • mccor023
                            • Jul 2011
                            • 683
                            Really? I thru on a m50 afm w ka motors cold air to compensate, do you still see them lean out?
                              • 37829
                              I guess it all depends on the chip.
                              Grover Beach, CA
                              www.BimmerHeads.com
