b25 harness to eta connector
  • F34R
    sLaughter
    • 12376
    Anyone know what wires have to be messed with to put a b25 into a 86 325?
    I have been looking and searching but nothing on doing the b25 harness work to swap it into a 86 325. The harness is from a 89 if that helps. And the eta car has the round harness connector on the car.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
  • acolella76
    • 2950
    If they both have round connectors it should be plug n play, not sure what you mean by they need to be messed with.
    -Alex
    • scottinAZ
      • Dec 2009
      • 1312
      most items should be plug and play. I would check the ABS wires to make sure that you arent connecting voltage to a ground. shouldnt take more than a few minutes in the ETM to determine any pitfalls
      I saved 15% on my Bimmer parts by switching to ...
      • acolella76
        • 2950
        If he's talking about the engine connector like i think he is... ABS wires wouldn't be in the harness.
        -Alex
        • einstein57
          • Jun 2007
          • 10780
          I was reading the build on strictlyeta.net and it said something about the obc plug and the econometer needed to be jumpered. Or switch to an I tach. Now my question is how do you convert a sqaure plug to a round plug?
          www.gecoils.com
          • acolella76
            • 2950
            there is a diagram in this thread: http://www.r3vlimited.com/board/showthread.php?t=100939
            -Alex
            • Eecen
              • Jun 2010
              • 1235
              Do some cross referencing on http://wedophones.com/BMWManualsLead.htm?
              • einstein57
                • Jun 2007
                • 10780
                Thanks for the info guys. This is is the only thing holding back my swaped 316i
                www.gecoils.com
                  • 37829
                  86+ has the round plug though Nigel, which is what the OP has.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • F34R
                    sLaughter
                    • 12376
                    Since I have the round plug it should be plug in and play? I was reading about people swapping and they were talking about splicing etc. I have the round connector on the car I am swapping to.
                    I just wanted to clear that up, I tried talking to a guy on e30tech that swaps lots of them. Seems he has not logged in for around 2 years. So I am sure he is not going to respond.
                    And the ABS, I don't think it has any.
                    Current cars:
                    ~ '87 535
                    ~ '06 X5 4.8is
                    • acolella76
                      • 2950
                      If you already have the round connector in the car that's being swapped it is plug and play, and no there are not any ABS wires in the engine harness.
                      Do you guys think there would be interest if i was able to make and sell square -> round harness adapters? I've made a few already.
                      -Alex
                      • F34R
                        sLaughter
                        • 12376
                        I don't see why not, I am sure they would not sell out crazy fast. But good to make up a batch and put a thread up.
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                          • 37829
                          The late model harness will plug and and it should run but there will be some wiring differences.
                          An 87 i/is engine harness is the best way to do it. Everything works perfectly, no splicing, cutting, or anything.
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • F34R
                            sLaughter
                            • 12376
                            Any idea what has to be worked on Matt?
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • E30Gus
                              • Jun 2008
                              • 781
                              Tach and econometer wires will need to be spliced.
