1990 325i
Problem: The car seems to idle a little rough...a slight 'rumble' every few seconds can be felt, and a very slight fluctuation in RPM at idle. When I turn on the AC the RPM jumps up to 2000.
Could this be an ICV problem? The ICV has a buzz and vibrates with ignition at ON position. I removed the ICV, cleaned it up a bit with throttle body cleaner, and checked for continuity. All within spec. However, when I unplug the ICV with the car running there is no change in RPMs. Is this a sign the ICV is bad?
