I am trying to diagnose a problem with an 86 325e. The car starts and runs for about 1 second and then dies. I can hear the fuel pumps running after it dies and I can feel the fuel going through the fuel lines where it goes into the rail and out through the FPR. It obviously is getting spark because it runs for that split second. If I turn off the key the fuel pumps turn off and will not come back on until the car is cranked over again. If you try to start the car again immediately after it dies it won't fire up, it just cranks. If you wait about two minutes it will catch again for that one second.
Could this be a crank sensor? I thought the e crank sensor did absolutely nothing as it goes directly to the diagnostic port.
Could this be the FPR? Maybe the rail is not getting enough pressure and all the fuel is just being pumped around back into the tank.
Would an ECU cause a problem like this?
It just seems to me to be a fuel issue, but I know both pumps are running and I can even get a whiff of gas smell when cranking so maybe too much fuel.
I thought about the AFM and disconnected it to see if the car would run without it, but it did the same thing.
I swapped relays just to be sure that wasn't the problem and like I said the pumps are running after it dies and don't turn off until the key is turned off.
Also bought a new main relay and that did not do anything either.
Could my idle computer be bogus?
Any thoughts or suggestions would be welcome. Thanks!
