I know their has been a plethora of threads about people's engines cutting out or stalling. But since this can be caused by many things I felt the need to post my own thread.
THE PROBLEM
I have done several test on sensors, fuel pump, ect.
This is what ive tested/replaced
I'm running out of money and don't have a lot of free time between school/work. So I would really appreciate any help or suggestions on what to do next.
Thanks for your time.
THE PROBLEM
The car, 1987 325is, will start ok (it cranks for a second then starts, I think it might be trying to gain fuel pressure.) then it will pull fine in first gear and ok in second until 2k-3k. Thats when it will normally sputter and sometimes dies. But if it makes it past 2nd the same thing with just happen in third or fourth gear.
When it sputters/hesitates the tach doesn't move and the econometer doesnt dive to 0. But if it flly cuts out and dies, the "check engine" light comes on and the revs slowly fall to zero.
Basically I'm wondering if it's a fuel or electrical problem.When it sputters/hesitates the tach doesn't move and the econometer doesnt dive to 0. But if it flly cuts out and dies, the "check engine" light comes on and the revs slowly fall to zero.
- main fuel pump flow test: was off by a little but not enough to worry me. It is also whining a dog.
- Intank pump was replaced by previous owner around may
- new spark plugs (bosch copper cores)
- new cap and rotor
- new ignition coil
- cps read 550 ohms
- new main relay
- new fuel pump relay
- afm tested fine
- injectors cleaned, plus new filters, caps, and seals
- fuel rail cleaned
- valve adjustment
- tps tested fine
- grounds read fine
- fuel filter
- air mass meter boot
