Quick question on what I should look into or expect to find...and how serious this is.....every time I start the car when its cold I hear this chirping/whirring sound coming from my belt area. I open my valve cover thinking its in there but its not. Which is good I think.....once the motor warms up it goes away and sounds normal..
Once I pull the throttle about 500 rpms it is blurred out by the engine, but right before it hits idle again you do hear that its rpm dependent and will increase in spewed with the motor.
Timing belt and water pump are recent.....about 9kthe on the water pump and a little more on the t belt.
Sound is def from the t stat housing or belt area....help please. This was all typed by my phone so sorry if its terrible to read
