Problem at Idle...
  • Schleckjr
    • 5
    Problem at Idle...
    HELP!
    Intermittent issue with my '89 325i. Its not Idle Air Control, MAF Sensor, timing, or anything else really obvious. Just wondering if anyone has known it to be anything else.
    thanks!
  • devon.818
    • Feb 2011
    • 2937
    vacuum leak
    • Schleckjr
      • 5
      not vacuum leak. Don't hear it and would a vacuum problem always happen? it wouldn't be this intermittent.
      • devon.818
        • Feb 2011
        • 2937
        do you have a bentley?
        you need to go through and start troubleshooting everything.
        • BergerNJ
          • Oct 2009
          • 349
          you wont necessarily hear a vacuum leak...smoke test is the only way....
          • slammin.e28
            שמע ישראל
            • 12054
            • MTechnikII
              • Jun 2007
              • 83
              sometimes wrong valve adjustment causes this too, but if you cant get a smoke machine for the leack test, get a plastic small diameter but maybe 3 foot long tube and place one end to your ear and the other end prob the locations you think might leack air, one place that goes mostly unnoticed is the "O"rings for injectors, you wont hear it when the engine running by listening to it, but with a tube you can clearly hear a hisssing noise when the engine is running.
              Good luck
              Henry
              and I hope your plugs are not platinum Bosch
              • EThirty318i
                • Dec 2010
                • 219
                either a vacume leak or its your MAF.
                • gtdragon980
                  • Jun 2008
                  • 1808
                  check that intake boot. notorious for cracks...otherwise get out a multimeter and get readings from each sensor and match it up with the bentley readings to see if they're good.
                  FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                  Originally posted by scabzzzz
                  I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                  1989 325i - Project/weekend driver
                  2002 325i - DD
                  2005 Suzuki SV650 - Toy
                  • custom e30
                    • Nov 2009
                    • 347
                    here is your prob, throttle position sensor
                    • 5Toes
                      • 9836
                      Get a can of carb cleaner and go nuts
                      • gorilla
                        • 113
                        have you had the intake off
                        Big Mike Hunter
                        BMW Enthusiast
                        Not2Close Motorsports
                        Like us on Facebook
                        https://www.facebook.com/pages/Not2C...35086986557277
                        • harold30
                          • Jul 2011
                          • 180
                          Check this out: http://www.verrill.com/car/idle/e30_idleproblem.shtml
                          HTH
