The car is mostly stock and will start perfectly when cold, but when hot it will crank almost run then die down. If you tap the gas a couple of times it will keep running though it will start alittle low on the rpms then work its way up. I really think it is the fuel pressure regulator but has anyone had this problem before??
anyone know about hot start problems??
i have the opposite problem of this, mine does what he mentioned when motor is cold. not trying to thread jack but any input would be appreciated.The car is mostly stock and will start perfectly when cold, but when hot it will crank almost run then die down. If you tap the gas a couple of times it will keep running though it will start alittle low on the rpms then work its way up. I really think it is the fuel pressure regulator but has anyone had this problem before??Comment
I had a no hot start problem on my M20, it was the Fuel pressure reg.
Pull the vacuum hose off the top of the regulator and smell it, if it even hints the smell of gasoline the regulator diaphragm has probably torn and the engine is flooding.
Also if gasoline comes out of the regulator vac hose with the engine turning over then you can be sure its the reg.
I remember when trying to start my engine it wouldnt start but while it was turning over you could smell the gasoline, then I pulled off the reg. vac. hose and bobs ur uncle fuel came out.Comment
ya know my car does this sometimes. i ran inside some place. waited for my food to finish cooking, got it to go and hopped back in my car. it didnt have enough time to cool down but when i went to start it it just kept cranking till i gave the throttle a little tap and it started right up. idled fine but it does this often. i wonder if its my fpr
can i just get an adjustable one instead.lolm20 is plenty. im simply a drifter.
build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510Comment
