Chatty Valve?
  • aTron12
    • Nov 2009
    • 98
    Chatty Valve?
    I have a resurfaced, rebuilt head that was installed a few years ago and since then my mechanic has done two valve adjustments since the initial install. I notice that when the motor is cold or if I am driving with my windows down, I am hearing a "clack, clack" besides the typical M20 sewing machine sounds. I can really hear it if I am driving past a retaining wall or a line of cars. Could this be a wonky valve or even something else? He is very adimant about keeping things spec and does great work otherwise. He's just a little harder of hearing so I wonder if he maybe just didn't catch it? Ideas or thoughts would be greatly appreciated.
    Adam
  • euromobbin
    • Sep 2011
    • 128
    my 325e is loud as f*** and the top end including valves and all that were done less than 40k ago
    the owner of the shop that did my rebuild said its two things: the injectors firing but mostly the SOLID LIFTERS
    he said if theres no noise theres a problem
    anyone have any info to back this up?
    my car sounds like a diesel
    • Jaxx_
      • Dec 2009
      • 1880
      the sewing machine sound is normal. if you hear anything louder than that (or deeper) you might have another issue. I would check the bottom end for any noise out of the ordinary. You can use a long piece of hose up to your ear and use it similar to a stethoscope.
      • aTron12
        • Nov 2009
        • 98
        It's not really any deeper. It truly sounds like a normal valve but just louder. Like a "clack clack clack" but just out of place. I'll try the stethoscope trick to verify where it is coming from.
        • LJ851
          • 7918
          M20 does not have lifters at all so they won't be causing the noise you hear.
          What can happen is that the tip of the valve can wear into the rounded shape of the adjusting eccentric thus causing an inaccurate valve adjustment using a feeler gauge at the valve. You can get a more accurate valve adjustment at the rocker to cam interface, but the spec is different because of the rocker ratio.
          Lorin
          The M30 is God's engine.
          • ROLLingKING
            • Apr 2011
            • 1169
            Brilliant. im getting my valves adjusted next week so ill ask the mechanic about this
            m20 is plenty. im simply a drifter.
            build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
            • bmwguy325is
              • May 2011
              • 1263
              Adam
              Most often when I hear clicking driving by a wall or somthing its an exhaust leak.
              sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
              The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
              • Ceeker
                • Sep 2009
                • 2821
                These are quite simple engines; aside from the mild ticking you hear from the injectors there is some valve noise which is inherent in this motor build. normal, anything louder or more excessive means they need adjustment or something is really worn. rockers surfaces are beyond tolerance and would most probably need replacing.
                if the valve heads are rounded this should tell you the amount of wear on the head and valves. If you got a rebuild- true rebuild - then you would have all new valves, rockers, cam, seals and necessary machining done. shops usually do a valve adjustment off the car and does work but ideally should be done once the head is mounted.
                • e21jps
                  • Aug 2011
                  • 44
                  heres a common mistake people make- the valve lash spec is 010 but thats at the valve where the eccentric sometomes wears a little hollow so the setting is not correct when you put the feeler gauge in, the result is too much lash. To solve this most people set the lash at the cam but because of the rocker ratio the clearence at the cam should only be 065" NOT 010" many mechanics just look at the spec of 010" and set this at the cam..... too much! so maybe your machanic has used the wrong setting, its verry common
                  the other thing is worn rocker shafts can sometimes "clack" a little when they get old
                  I sell ITB's and performance parts www.racehead.com.au
                  e21 race car m20 power! 293Whp atmo 2.9
                  details here http://e21jps.webs.com
                  drive by video http://www.youtube.com/watch?v=kOdPbErYlho
                  incar race http://www.youtube.com/watch?v=sbr0ZCmjsYM
                  incar video http://www.youtube.com/watch?v=aQyvDR-B00A
                  drag racing http://www.youtube.com/watch?v=7XmznH6PND4
                  • Vince30
                    • 2318
                    A ticking m20 is a happy m20
                    • e30:)
                      • 728
                      i used to get asked if my first e30 was a diesel lol.
