E30 aluminum rad (early model)
  • Genkboy8o8
    • 171
    Is there any bolt on aluminum rads that go into the early models? Been searching for awhile and have gotten nothing, but doing 88+ swaps, which I don't really intend to do.
    Video I made of my car: http://www.youtube.com/watch?v=WGg8GixF8Ds
  • Genkboy8o8
    • 171
    No input? Should I stick with a oem behr even if I plan to go turbo soon?
    • Genkboy8o8
      • 171
      No input from anyone? Should I just stick with a behr oem brand even if I plan to go turbo soon? I heard our stock cooling system is more than enough but I'm concerned if it'll cool enough with a inter cooler in front of it?
      Anyone??
      • misterYthirty
        • 31
        I havent seen one, been keeping an eye out myself.
        A custom rad is only 300-500 max anyway.
        • Wanganstyle
          • 2828
          I installed a PWR radiator from my e36m into my early model e30. Write up on m20 forum, used all stock parts to do it besides aftermarket radiator.
            • 37828
            There's no real need for an aluminum radiator. Go with a nice stock replacement.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • CW325
              • Jul 2011
              • 1434
              if your going turbo you should probably convert to a late model cooling system so the expansion take is out of the way of the turbo
              • Genkboy8o8
                • 171
                Is there a write up on how to convert to a late model radiator? I've tried searching, but I just can't seem to find one... probably not using the right key terms?
                do I have to modify the mounting points or radiator support at all?
                • Wanganstyle
                  • 2828
                  Search the M20 section, late model into early radiator- thread w photos is there.
                  The super proper way is to change to late style cooling system w hard pipes also and expansion tank
                  Rad mounting updates plug and play to late style
