problems and opinions (idk! maybe not work safe gif in here btw)
    okay so I have a m20b27 with idk mile and its a piece of sheet....it knocks like crazy! Idk if its a main bearing or if its a rod that broke through the piston and it hitting the head or something like that but here are my problems
    and at the moment I have no o2 sensor but that should not be the cause of the problems I am having
    problemo numero uno: so my car smoke like that one guy from triple x the first one.....you know that one Russian guy who gets blown up by the heat seeking missile... Anyways...what do you think is causing that?
    problemo numero due: so it takes for ever for the car to start I need to crank it like 10000000 times then stop then crank it till is fires on 1 or 2 piston then stop then start for like 30 secs then it starts to fire them stop then start then it goes.....idk wtf it is....idk if its the fuel pump or what. But when I unhooked the fuel line and cranked it fuel spewed out everywhere and fast.....after cranking it 100000000 times I checked the plugs for flooding and it wasn't gritting gas.....but when it finally starts and I shut it off it starts right back up with no problems....thought it was the injectors but I just changed them
    problemo numero thre: so once I finally get the car runing if I floor it it chokes out sometimes and will back fire through the intake....so on occasion it will choke out if I give it gas to fast but sometimes it doesn't. Sometimes if I slowly give it gas it chokes and when I push it fast it has HP's
    what do you dudes and dude'ets think :hitler::yawn:
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
    I'm going to maybe m30 swap it or m50 later in like 5 months
