engine problems in the rain
  • e30:)
    • 728
    so when it rains or is really humid out my car will have a very hard time accelerating, it misses and bogs down. i have just replaced the cap and rotor with no change and the plugs are fairly new too and look fine. im stumped any ideas? i dont wanna throw anymore parts at it till i have a good idea of what it is
  • LJ851
    • 7919
    Plug wires.
    Lorin
    The M30 is God's engine.
    • kid325e
      • Sep 2007
      • 6422
      Good start. Have you done the cap and rotor recently? Checked for vacuum leaks? I know this may seem stupid but check the basics! Does it run good when it's dry out?
      clutchCTRL!
      Move with a purpose.
      - 1991 325iX 4dr/5spd
      - 2000 323i AT
      2016 Mazda CX3 Sport AWD
      • atldohc
        • Nov 2008
        • 359
        you could try filling a spray bottle and misting the cables. if you see arcing or it starts to stumble you found your problem
        • Ceeker
          • Sep 2009
          • 2821
          As far as my history with these cars is...we rarely had to change the wires. Although this sounds like the most likely culprit. Keep in mind it can be any wiring that is exposed to moisture in the engine bay that is connected to the ign system. Wires get brittle and old and start to crack.
          • MonkeyMadness
            • 3251
            water in the tank?
            Condisation maybe? if no water in tank, try this cheap but offten over looked part: fuel filter..
            I know it sounds funny but you would be suprised..
            • e30:)
              • 728
              well as of now i have replaced the fuel filter, cap, rotor,plug wires, temp switch its not raining now so it runs fine but still stumbles and bogs if i drive through a real wet spot on the road. i have no clue were to look now. i don't think its water in the tank because it runs fine when its nice out.
              • JrCamacho
                • Feb 2011
                • 618
                Ground strap, check that sucker out! Mine was completely bare and was super stiff, wires shouldnt be stiff as this was. It did help mine ith smoothness of acceleration.
                • e30:)
                  • 728
                  well i still cant find the problem.. this week it has been fine besideds a few misses here and there. but now its pouring and i can barely drive the thing. if i rev it with the clutch in i can here it "popping" in the muffler.. does anyone have any other ideas i can check out? pleeeeaaasssee help
                  • e30:)
                    • 728
                    also if i slowly rev the motor it stumbles bad and pops in the intake
