M20b25 starting rough (TPS Code)
  • Mr. EG
    • 270
    I recently purchased an E30 and it runs decent, but stutters and bogs every great while and the CEL illuminates every trip. I used the stomp method to pull the code and it was...
    Long blink (I believe that would count as a 1)
    pause:
    One long blink
    pause:
    2 Long blinks
    Pause:
    Six short blinks
    I have no idea why this code is not showing on the CEL FAQ, but I believe its the TPS sensor. It makes sense that the potentiometer is getting stuck and not reading the correct throttle position. The car is a 89' 325i all stock 5spd with an M20b25.
    This is the site I am working off of. http://e30world.com/fuel/BMW-E30-DME...ic-fault-codes
    EG Hatch- ITR Powered, 4 door Gs-R-stock, 89' 325i
  • Mr. EG
    • 270
    I also wanted to mention I tried cleaning the pins and the connectors and it did not help. I believe I need a TPS (3 wire), i would just like others opinions.
    • nebulous123
      • Jun 2011
      • 923
      hesitating could also be linked to the MAF. you have to cut the silicon glue off. you also have to clean the copper and bend the needle so it makes good, fresh contact. should help with that.
      '84 325e - "Elizabeth"
      '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
      • Mr. EG
        • 270
        Thanks for the info.
        • DaveSmed
          • Apr 2007
          • 1407
          I would not suspect the TPS. It's a "dumb" two position switch, idle and wide open. All load data is from the airflow meter.
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • Mr. EG
            • 270
            What exactly is the "airflow" meter? Are you referring to an O2 sensor. And my code indicates a TPS issue
            • ttrousdell
              • Nov 2009
              • 1770
              This is the maf it is located on the intake before the throttle. It lets the ecu know how much air is coming into the engine and will effect fuel injection. A defective maf will also cause the symptoms you describe.
              The Build:
              • Mr. EG
                • 270
                Awesome, I will look into that also.
                • blocke
                  • 1305
                  Curious how the stomp test would work if the tps is bad?
                  Parts Wanted
                  The Never-ending Resto Mod
                  • Mr. EG
                    • 270
                    It illuminates a code. My code indicated it was a TPS issue.
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      That code is wrong. Google e30stomp test and read. The long blink is the sign it's entering in to the diagnostic mode.
                      • blocke
                        • 1305
                        What I meant is the a functioning TPS sensor is a prerequisite to the stomp test working. If it doesnt register WOT and closed throttle, the stomp test wont work.
                        Parts Wanted
                        • Mr. EG
                          • 270
                          I believe it gets stuck in certain RPM ranges (potentiometer issue). I will be replacing both the AFM and the TPS.
