I've been having a persistent Thermostat housing leak from the bottom of it. I recently replaced the hoses and clamps at the bottom of the t-stat thinking this would solve the issue, but it only reduced it. After the job, I cleaned it up again and still have minor seepage from the bottom side of the thermostat housing. I was able to tighten the bottom bolt up a little more, but don't want to break it. Should I just go at it? FRAGILE?
I placed form RTV sealer in that area, but that just minimized it slightly. Now it's coming down from the side again.. RTV it all around?
Is there some sort of gasket other then the rubber o-ring that goes in there? I recently replaced the T-stat and the o-ring when I did the water pump and the timing belt.
Any help will be appreciated..
Thanks in advance!
Thanks in advance!
