Hi guys, Here's my story. i have 89 325i automatic transmission. i did a manual swap with 87 325e tranny with e46 m3 guibo with big center hole but the bolt patterns fit perfectly. since the center hole is big, the drive shaft's tip is too small to fit in guibo's center hole. i look at realoem and found out that guibo's part #: 26117511454 from here.
if the part number above is incorrect, please provide me the correct one with perfect fittings in center hole and bolt patterns. also, is vibration damper is needed?
i need your input guys coz the guibo i currently used is giving up because only the bolts is holding the tranny and drive shaft's flange. thanks in advance!
