Miller stuff
  • bastianshaw
    • Jan 2007
    • 2210
    Miller stuff
    so the PSIK is $300 more than just the MAF and for that you get a down tube and K&N filter? huh?
  • bmwguy325is
    • May 2011
    • 1263
    From what I know as I have talked with them a bit is that you get a few things. You get the 3inch pro maf in the PSIK. Plus they have you bypass the coolant hoses that go to the throttle body. I have the 3inch MAF and a war chip anf love it. Best bang for buck I have spent on the car.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • CarsSuck
      • Oct 2005
      • 968
      I have a miller MAF conversion, no WAR chip. Its been good for me so far.
      That said, the throttle body is heated for a good reason. You're definitely not gaining anything by getting rid of them. The whole intake manifold gets hot as shit, who gives a rat's tail about the throttle body being warm (and free of ice)? Because the throttle is always under vacuum, water can freeze at a much lower temperature than you would expect.
      --Will
      • bastianshaw
        • Jan 2007
        • 2210
        huh?
        isnt it heated because of a venturi?
        drop in pressure=drop in temp=ice<--------heated=fixed
        • bastianshaw
          • Jan 2007
          • 2210
          Does the MAF come w the same chip as the psik? if so, I can fab my own down tube for WAY less...
          • bmwguy325is
            • May 2011
            • 1263
            ....... The whole intake manifold gets hot as shit, who gives a rat's tail about the throttle body being warm (and free of ice)? Because the throttle is always under vacuum, water can freeze at a much lower temperature than you would expect.
            Originally posted by bastianshaw
            huh?
            Are you serious with this comment? This isnt a Cessna with and up draft carb. Its venturi action and fuel atomization that cause carb ice. As you also stated the intake get hot. HMMM Heat transfer maybe? Though My s14 did ice over once with all those non heated ITBs
            No they change the tune you get with the PSIK. I mean I am sure you can build your own. However they have tailored the tune for the 3 inch maf and the down tube.
            • bastianshaw
              • Jan 2007
              • 2210
              Thanks I didn't get what car suck was talking about. W the tb
              • CarsSuck
                • Oct 2005
                • 968
                its Boyle's Law, dude. Things freeze at lower temperatures at lower pressures. My point was really that there isn't any benefit, and there's a very small chance that you might encounter a problem as a result.
                --Will
                • bastianshaw
                  • Jan 2007
                  • 2210
                  so you have to diconnect the hoses to the tb w the psik?
                  • ROLLingKING
                    • Apr 2011
                    • 1169
                    hey bmwguy325is! ive been meaning to talk to u
                    ive heard the war room is shut down. how has your MAF and WAR chip been doing without that online tool. i was going to pull the trigger on the MAF and WAR but im having trouble talking to them on the phone also now. i want to reach someone first and talk about a base tune before i just pay them
                    m20 is plenty. im simply a drifter.
                    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      yeah WTF why did they close that?
                      • ROLLingKING
                        • Apr 2011
                        • 1169
                        to kind of answer what youre thinking...
                        if u go to the website they have a dyno graph of an M20 with the MAF and without...then a dyno graph of an M20 with and with out the PSIK. the gains of hp for the PSIK are claimed to be 25. i cant remember but i think the HP and torque were that. The MAF dyno chart also has like +23 hp and tq. so its pretty much the same.
                        im gonna try and find those dyno charts now :-|
                        • bastianshaw
                          • Jan 2007
                          • 2210
                          So I'm not tripping, 50% for another 2-3 hp?
                          • The Humjet
                            • Jun 2010
                            • 528
                            To answer a few of your questions this is what Brody from Miller wrote on e30tech a while back when they first shut down the W.A.R room.
                            Originally posted by Brody
                            Also, about the WAR Room, there was a major security breach a month ago on our website. The vulnerability stemmed from the WAR Room. At first, the WAR Room was closed to new memberships (not a free thing) and was closed because of some fuss from a competitor.
                            After the site attack, we disabled the WAR Room for security reasons. Whenever someone needed a file I would always send it to them.
                            • ROLLingKING
                              • Apr 2011
                              • 1169
                              I have also been emailing Brody from Miller the past couple days about this. I have been interested in ordering the miller maf and war chip for a while. But im also planning to turbo the m20 in about 8 months so i need reliable tuning from miller products not just in NA applications. He is emailing me back and answering all my questions promptly, so I think i really go with "MILLER STUFF" rather than Mega Squirt.
                              But here are the graphs:
                              stock 2.5L M20 vs. 2.5L M20 w/ miller MAF: http://millerperformancecars.com/fil...III%202.5L.pdf
                              stock 2.5L M20 vs. 2.5L M20 w/ PSIK: http://millerperformancecars.com/fil...0vs%20PSIK.pdf
                              Then they did another dyno run which to mean doesnt really mean a damn thing. who knows what the hell they consider to be "psik with supporting mods"/ im guessing an exhaust and differend intake filter/set up. cams or larger valves. who knows.lol here it is stock 2.5L M20 vs PSIK w/ supporting mods M20: http://millerperformancecars.com/fil...vs%20Stock.jpg
