Stripped connecting rod bolt. HELP
  • Bart021
    • Dec 2009
    • 16
    I have two bolts that are stuck. I destroyed the tread on trying to remove it with vice grips. I am at a loss, can someone help me out?
  • MonkeyMan
    • Jul 2011
    • 426
    well, it goes without saying that you're gonna need new bolts anyway - so what you can try to do is either use a bolt extractor on them, or cut a slit across the top of the head of the bolts wide enough to jam a beefy flathead screwdriver in there horizontally and then just add leverage (a pipe, jackhandle, etc) to get a good turn on them..
    good luck, man..
    Make the bastard chase you.
      • 37833
      How the hell does this happen? Not using the correct torx?
      Grover Beach, California
      BimmerHeads.com
      • AndrewBird
        The Mad Scientist
        • 11898
        I would weld a nut to the head of the bolt and use a breaker bar.
        • Bart021
          • Dec 2009
          • 16
          That is a good question MR325. The rest of the bolts seemed to agree with the torx socket I was using. There is always one isn't there.
          I don't have any welding gear available at the moment. But that's a good idea.
          • Bart021
            • Dec 2009
            • 16
            Well I wound up grinding the bolt flat on two sides and using vice grips and heat. She's out. Thanks for the suggestions though.
