325e head swap
  • masterman56
    • Nov 2011
    • 8
    325e head swap
    I have decided to swap out my head to an 885 from a 325i
    I have read a bunch of threads and posts, but none of them have a full detailed list of parts i need to do the swap.
    I know so far, I need:
    - 325i head
    - 325i intake manifold
    - 325i ECU
    - 325i AFM
    - 325i injecters
    - do i need a 325i or 325e head gasket?
    What else am I missing?
  • jaysee
    • Sep 2011
    • 82
    you do relize it will be lower compression because the 885 uses a domed chamber and domed pistons?
    • jaysee
      • Sep 2011
      • 82
      and i believe the head gaskets are the same, but if in doubt use the i same as the head
      • Cabriolet
        • 9620
        the gaskets are the same. you arent gonna be able to run that head unless you get custom piston heads made. or a big turbo.
        dont use victor rienz gaskets. i did last year and the headgasket started leaking after 50 miles.
        Much wow
        I hate 4 doors
        • masterman56
          • Nov 2011
          • 8
          I was planning to turbo it, but for the parts wise, is that all i need?
          I would change the pistons, but isnt that hard to do?
          • Myster-E
            Performance
            • 552
            You will also need an 87 I or iS wiring harness for everything to work correctly like windows. Must be from an 87
            1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
            Visit www.BimmerHeads.com for all of your 12 valve needs!
            • masterman56
              • Nov 2011
              • 8
              Would it be easier just to do a m50 swap instead?
                • 37834
                Please don't give out incorrect information. You can run that head and it will work well. With a port/polish and a cam it will pull just as hard or harder than a 325i. This is real life first hand experience, not internet hearsay.
                Grover Beach, California
                BimmerHeads.com
                • masterman56
                  • Nov 2011
                  • 8
                  So with out changing the heads the engine will run fine without a turbo?
                  I was thinking, Why do I need to change the wiring harness? All I am doing is changing the head, so everything should hook up fine right?
                  • kharv
                    • Jul 2010
                    • 6
                    I think its because your accepting a different fuel managment system for the injectors on the 325i head. so you would need the wiring harness for the computer to connect
                      • 37834
                      Yes it will run fine NA. I would recommend adding a cam though.
                      You need the i wiring harness to work with all of the i sensors and ECU.
                      BimmerHeads.com
                      • masterman56
                        • Nov 2011
                        • 8
                        Is the harness hard to swap out and replace? It sounds complicated haha
                        Isnt the 325e ECU plug in the same as the 325i?
                          • 37834
                          If it was the same we wouldn't be telling you to change it. Swapping an engine harness is easy.
                          BimmerHeads.com
                          • masterman56
                            • Nov 2011
                            • 8
                            alright thanks guys, wish me luck
                            I was looking up on how to remove the harness.. and it looks complicated
                            Do i really need to remove all those wires?
                            • CW325
                              • Jul 2011
                              • 1434
                              you should probably find an "i" cluster considering how much higher the revlimit will be with the new head
