Just finished up a head-gasket job where I used a different head that came from a donor motor. I tested the head as best I could for flatness and made sure all the valves sealed tightly before install. I cleaned it up really well and inspected all the rockers and springs as well as the cam for damage and wear.
The car fired right up when I was finished but there is a ticking sound coming from the valvetrain, not the normal ticking. I tried to isolate it with a stethoscope by pulling plug wires one at a time...nothing. I triple checked the timing and it is right on. I did a compression check and all is well.
Tomorrow I am going to do a vacuum test and re-check the valve adjustment.
What else should I check?
