sounds like a belt and it's more pronounced in the cold and damp or rain but they r all new 8 months ago. could it be a worn pully and still go away after the engine warms up? if it is a pully, can they be sanded to take the smoothness out? the belts really don't feel that loose.
belt or pully
Tags: None
Yes you can sand the pulleys a bit. Emery cloth works OK.sounds like a belt and it's more pronounced in the cold and damp or rain but they r all new 8 months ago. could it be a worn pully and still go away after the engine warms up? if it is a pully, can they be sanded to take the smoothness out? the belts really don't feel that loose.
Also, spray some water on the belts while its running and see if the squeaking is more pronounced or if it quiets down.Comment
