Any tips on swapping heads
  • e30strokr
    • 211
    Hi new member here doing the "stroker" kit tonigh
    Lil background here; had all mods on GTI and I wreck, needeing a commuter car I got an ETA since I always liked the E30's well I found out it was a Super ETA and I got the gofast bug again!
    88 SETA
    I have :
    "I" head
    ECU with Dinan chip
    17 lbs injectors
    M30 FMA/ MAF?!
    timing belt kit
    head gasket kit.....Victor Reinz
    is there an issue with the Reinz gasket? do they all leak? I was once told to add copper spray on the head gasket for my VR6.. will this help on the leaking issue iwth my E30?
    any other tips?... we are probably going to try doing it tonigh for the BMW meet in Milpitas on Friday... I got to keep up with my friends s52 and modded 325I...ok maybe the 325I only hahah
    I've never seen a used head that didn't have enough warp to justify at least a minimal surfacing cut. And before I'd install a used head I'd have the valves ground, check the guides/cam/rockers for wear, and replace the seals.
    I've used the Reinz gasket a number of times on Spec E30 engines and not had a problem. But others have had problems and swear by the BMW OE gasket.
    • riceh8r
      • Dec 2010
      • 133
      i used the reinz...torked as spec'd (with new head bolts)...no leaks
      • SpecM
        • Oct 2005
        • 4531
        I've had a oil leak with my Rienz head gasket. I recommend a Grotze (I think that's how it's spelled). All other gaskets are fine to be V-Rienz
        And def use new head bolts. Might as well get a new water pump while its all apart if it looks remotely old.
        To make a 2.7i make sure you use a b25 intake manifold, throttle and air boot. Don't bother with an m30 AFM, just use a known good one from a m20b25
        Sent from my Vortex using Tapatalk
        1989 cirrisblau-metallic 325i
