Hey guys,
Sorry for the long post in advance.*
I am new guy to the forum. I was looking at 1989 325i in my area a few weeks back and missed out on it. Fast forward to more recently. I found a 1990 325is in Phoenix (I am from Denver). So I made plans to buy it and flew down this past weekend to pick it up. Few little things here and there, but pretty much original and in great shape with 175k miles. * I drove east into Albuquerque and it was winter condition and very cold. Engine was running way to cold. Figured the thermostat was stuck open. * So I found some cardboard and stuffed it in front of the radiator. It ran much warmer but not quite in the middle. * Good enough though. Drove it home 800 miles no problem. Parked it last night outside (0 degrees F) very cold. Started up this morning to wash it a bit and put it in storage for the week cause I am traveling. Drove it and it immediately started getting much hotter than it did the last 2 days and hundreds of miles and got above center and towards red quickly. I should have turned the heat on or stopped and removed the cardboard but I didn't. *Stupid I know. Anyway it got to the red for about 3-5 minutes and about 2 miles or less and a radiator hose burst (surprise). I shut it down shortly after washed it a bit and started it again (15-20 minutes had passed) and ran it for less than a minute to get it into storage. This whole time the temp outside is single digits. *
FYI, the car has a new timing belt, water pump and radiator in recently and also some head work done, but may have a missing or stuck thermo. *Been an AZ car it's whole life and probably never seen cold temps like it did the last 3 days.*
I have a few questions:
- why did it get so hot so fast today and it didn't the last two days? *I know the short answer is the cardboard blocked air and over heated it, but it's colder now than on the trip where it ran a little cool and below half on the temp gauge *and the cardboard is covering less than half the radiator. *Seems crazy it got so hot so fast which is kinda why I didn't stop. I figured no way it got that hot that fast. But I was wrong. What do you think, slower driving speeds, frozen coolant?
- how much damage do you think was done? *Obviously this is not good, but how bad is it for the engine? *Water pump? *
I already ordered a new thermostat. I guess I gotta get some new hoses too.*
Anything I should look for damage wise? *Anything else to replace? *Would the head or gasket be damaged by this?*
I appreciate the help. I feel so bad for the little car. *Hopefully i didn't hurt it too bad.*
