Hey guys, after two days of working on the car I ran into a problem
I recently changed my oil pan gasket. I initially tried Yoshi's diy on another forum. This method consist of removing the oil pump while the oil pan is sitting on the subframe. After I removed the two right bolts that hold up the oil pump, I realized it would be easier to just drop the subframe since I'm swapping in e36 rack.
When the oil pan was removed, I put back the two right bolts that I removed. I remember that the oil pump shifted when I tightened the bolts down.
my question is, would this cause the engine to vibrate? when the car is on, it feels like i have solid motor mounts, the whole car vibrates.
TIA
TIA
