So I have been doing some engine work on my silver car, "Elizabeth" and she is getting every gasket, belt and hose replaced that I can get to. So I took the intake manifold to swap out the gaskets and found that the return line for the heater core was toast. So I started to make a parts list for what I need and starting looking into what other hoses are hooked to the heater core and stumbled upon the 2nd thermo that connects to the block and feeds the inlet for the heater core.
I have never been able to get heat in the car and always assumed that there was something wrong with the valve in the heater core but I am thinking now that this 2nd thermo is the issue. The car has no issues with overheating of any kind and I wanted to convert it to the later early model way which I think is just a T-connector.
Here is the link to what I have, just wanted anyones thoughts on why or why not do it.
http://www.realoem.com/bmw/showparts...35&hg=64&fg=99
Should I just have a new hose off the block feed into a T-connector that feeds the inlet for the heater core and bypass to the return hose?
