1987 325E M20B27
from cold to warm/optimum temp (needle right in the middle) it idles fine. as soon as it reaches optimum temp, THEN it begins fluctuating from normal idle (~700) to ~1000 rpm. sometimes it just stays at 1000 rpm depending on the outside temp/weather. could it possibly be a vacuum leak since a high idle usually means that or even my TPS? possibly even a coolant temp sensor? i've done research but everything comes up with different symptoms than mine. thanks for all the help!
