Radiator Suggestions
  • jules325i
    • Jul 2011
    • 353
    Is it worth getting another OEM Radiator for my stroker or is there any direct fit alternatives that will offer me better cooling.
    329i
  • MaksV
    • 1042
    there are no direct fit alternatives that offer better cooling. Suggest getting an Efan if you need better cooling. All Alum radiators are nice too, but dont really offer better cooling.
    CHEAP REBUILT INJECTORS
    Need Quality Brakes? BimmerBrakes has it!
    For anything Else go with BluntTech!
      That depend on the rest of the cooling system. If the cooling system is configured to be the later (from 9/87) there are several drop-in possibilities that will yield increased cooling system performance. But if you have the earlier configuration you are stuck with the stock radiator.
      • jules325i
        • Jul 2011
        • 353
        My car is 1989.
        Is there any direct fit nice looking aluminium rad that has the same cooling ability as stock.
        Any brand names/ supplier.
        329i
        • paperplane94
          • Jul 2011
          • 420
          Mishimoto Mashimoto...something
          Oh, here it is:
          HANG ON, I think that might be for the M3...correct me please.
          • jules325i
            • Jul 2011
            • 353
            Oh, here it is:
            Yeah that link is for the m3 but i think they make one for my car.
            Do you know anything about the quality.
            329i
            • bubbajan21
              • 1962
              You will need the E36 one, it's the same one as a late model E30 radiator.
              I've been running a Mishimoto in my M50 car for a while now and I have had zero issues or complaints (well ok, one complaint is that there is no bleeder screw like the stock rad, but that's not a big deal once it's bled). I'm very happy with it, I wouldn't hesitate to use one again. And as an added bonus, it pretties up your engine bay with a shiny aluminum radiator :p.
              • SpecM
                • Oct 2005
                • 4531
                I'm going to be installing an 00-01 e36/7 S54 radiator. Strait drop-in for a '88+ or e36
                Sent from my Vortex using Tapatalk
                1989 cirrisblau-metallic 325i
                • SkiFree
                  • Jun 2011
                  • 2766
                  What is your definition of quality?
                  Mishimoto, IE, anything under $500 is going to be made overseas. If your definition of quality is "anything not made in China" then be ready to pay accordingly.
                  If your definition of quality does include "made in China, but has some level of quality control/warranty" then IE or Mishimoto (or simular) would be a good bet.
                  Frankly your OEM unit should be just fine, if you notice it getting warm THEN look into it.
                  ADAMS Autosport
                    • 37829
                    There's no need for an upgraded radiator in these cars. If your stock stuff is in good working order it will stay as cool as a cucumber.
                    I like Nissens or Behr for stock style replacements.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • MattBimmer
                      • 339
                      I'd go with the Mishimoto the aluminum rad. Everything I read when replacing mine was that these are great drop in radiators. Plus The aluminum radiator is gonna be less hassle than one with little plastic sides.
                      IF YOU CAN afford it go with the Mishimoto, if you want to cheapen up and save weight and do a M42 radiator swap, Ebay has a deal on Z3 radiators, the same thing as M42 for 70 dollars! hope that helps
                      • jules325i
                        • Jul 2011
                        • 353
                        Thanks everyone i think ill go with the Mishimoto.
                        329i
                        • jules325i
                          • Jul 2011
                          • 353
                          I can only seem to find the e30 m3 Mishimoto is that the same capacity as the 325i OEM.
                          Or will it fit.
                          329i
                            • 37829
                            The E30 M3 radiator is a different style. As said above, buy one for an E36 M3 and it will be the same.
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • jules325i
                              • Jul 2011
                              • 353
                              cheers
                              329i
