Intake Pipe Breather thingy....
  • bmwguy325is
    • May 2011
    • 1263
    OK so I had a smoke test done on my car today. The pipe that comes up from the oil pan to the intake is most likely the culprit of my high idle.
    My question is how hard is it to change? Dose the entire intake have to come off?
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
  • acolella76
    • 2950
    They don't call it the bitch tube for nothing. No the intake doesn't have to come off. I think there is a DIY somewhere out there, just google 'm20 bitch tube'.
    -Alex
      Yes, the intake will have to come off to change the seals on that tube.
      • moto650
        • May 2011
        • 155
        Correct, You can get the tube out without removing the intake.
        Yes, (at least for me on M20) as my top seal was stuck good to the intake manifold.
        To get manifold off I disconnected fuel lines, injector harness, drained coolant, removed thermostat housing and throttle body. Maybe more than "needed" but intake track was gross from the ERG gunk anyways so good excuse to clean it all up shiny. You will need new intake manifold gasket to reinstall and maybe throttle body too.
        88 325ix, 72 Type 1, 81 Starlet
        • paperplane94
          • Jul 2011
          • 420
          Just a tip: When you compress the spring you can hold it in the compressed position with zip ties. Then you are free to stick it into the block and lower the manifold on without any issues. Once its positioned correctly just cut the zip ties off and it should seat properly.
          • 5Toes
            • 9836
            Mine might be the source too... it wasnt that hard to get back on though
            • e30trooper
              • 11576
              where to get these seals
              OP , its easy to get off and on , zip ties
                • 37829
                Get the seals from any parts supplier, o-ring on top and o-ring on bottom.
                Do new intake manifold gaskets at the same time, it's all really cheap.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • 325ix
                  • Aug 2009
                  • 7783
                  If you have a friend, or two the "bitch tube" is quite easy.
                  • bmwguy325is
                    • May 2011
                    • 1263
                    Looks like I am in for some fun. HMMMM I think Ill pay someone LOL
                    • walktheboard
                      • 347
                      the bitch tube has never really been a bitch tube for me, quite simple actually. I don't think I've ever messed with it with the intake still on, though.
                      Originally posted by e30hijinks
                      I move faster than "the speed of light." I'm always connected to my Blackberry and am ready to purchase at a moment's notice. I do not play games
                      • acolella76
                        • 2950
                        Mine is so old and covered in oil that I don't even need zip ties to hold it down... i can just kind of push on it and it'll stay down. Doesn't leak either. Nice.
                        -Alex
                          • 37829
                          You don't need a friend and it's NOT hard.
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • 325ix
                            • Aug 2009
                            • 7783
                            It's really not, it's just stupid easy with someone.
                            • Ninz30
                              • Nov 2011
                              • 245
                              Zip ties is a good idea... maybe a friend for moral support???
                              My 1991 325i Cabrio Build
                              http://www.r3vlimited.com/board/showthread.php?t=227529
