M20 cold idle troubleshoot
    OK, I know this is common, but I'm just not too familiar with the M20s and it seems I've taken most of the immediate corrective actions already, (89 Ix) car has been a rough cold-idler for a while but has gotten worse lately.I changed out the blue coolant temp since this seemed like a likely candidate, the old one crumbled. Car has all new intake gaskets from some previous work, I swapped the ICV with a known good one, no change. New intake boot, nothing. Everything is plugged in, no check engine light, no intake leaks I can find. It's only when cold that the car stumbles, once warm it runs like a dream. What's next?
    Thanks
    Tried recalibrating the TPS?
    Leave Me Transaction Feedback
      Plugs wires try smoking the intake system see if that gets you anywhere I had a m20 cabi come in the other day poor idle was from rear seals @ valve cover
      "God created turbo lag to give V8's a chance" Taylor D.
        Unless you know them to be less than 5 years old, replace the plugs, ignition wires, distributor cap, and rotor. Use NGK ZGR5A plugs only. Adjust the valves, check the rail fuel pressure, and have a shop run a smoke test on the intake can crankcase.
          Solved
          I decided to go through everything one more time, lo and behold I found that the center prong of the connector to the TPS had broken off, I soldered on a new plug and she fired instantly at -10 degrees, perfect 900 rpm idle. Gotta love 25 year-old cars.
