High Idle Been there done that....
  • bmwguy325is
    • May 2011
    • 1262
    OK so I have a 300K 325is. It has a miller MAF kit and headers. I double checked the values for idle in the ECU and they are correct.
    I have replaced the intake boot, ICV, resealed all of the various pipes around the throttle body, changed all the hoses on the intake the fuel pressure line too. I did a smoke check and smoke came form the tube of death/bitch tube.
    SO today I replaced the orings on the tub o Death and still have a high idle.
    Car idles at 12 pretty steady.
    Any suggestions on where to go from here..............
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    Check the TPS for operation of the idle switch with a meter or test light. The idle switch should close when the throttle arm is 0.030-0.060" off the idle stop screw. Also clean the ICV with carb cleaner until the vane moves freely. A good ICV should vibrate when the ignition is on if the idle switch in the TPS is good.
    • Ninz30
      • Nov 2011
      • 245
      Ill leave this here. I think its something to try and isn't very difficult.
      http://pelicanparts.com/bmw/techarti...leshooting.htm
      My 1991 325i Cabrio Build
      http://www.r3vlimited.com/board/showthread.php?t=227529
      • bmwguy325is
        • May 2011
        • 1262
        The ICV is brand spanking new so I hope it need no cleaning.
        I will try the messurments on the tps. The guy who did the work simply unplugged it and the idle ran high.
