As most of you know, I prefer to use the 87 i wiring harness when doing an i swap in to a pre-88 car. Well since a friend of mine is not doing things this way, I've got a quick question...
Now I know that everyone says that the black wire from C104 needs to go to black (pin 9) at the C101. What I am wondering, couldn't this be tapped near the ECU connector and achieve the same results without running a bunch of wire? I believe I read that the black from C104 can be connected to pin 6 at the ECU but I haven't found enough info confirming this.
Thanks fellas.
Thanks fellas.
