Oil in the coolant
  • nick.cbr
    • 45
    So the head is off and no real signs of oil passing by the gasket into the coolant.
    There was no coolant in the oil but a nice coating in the thermostat housing, overflow tank, on the cap etc. The way things came apart so easily leads us to believe the engine had gotten a head gasket not long ago. The heat shields were also visibly new and the bolts came off the studs to the exhaust manifolds fairly easily.
    It's interesting to note that a few of the intake bolts were loose, there was some interesting shade tree mechanic hack fixes and given the newish head gasket (non-OE) was in there, the oils hex style head bolts were still used.
    Right now the head is at the shop getting pressure tested and milled if necessary. I have a feeling that the block may be cracked somewhere though - this feeling will likely increase if the head is fine and pretty flat. If there's a twist to it, there might be a chance the bottom end is fine but I'm not getting my hopes up.
    What's an iX short block worth anyway?
    Bottom line is I should have not let my emotions get in the way of common sense and mechanics as its been almost 100 bucks a day it seems since I've gotten the car :)
    I'll update more tomorrow. So far so good. The guy working on the motor has a good grasp on the M20 so I have no doubt once we get over the initial hump of replacing everything, this car is going to be fantastic (till the front axle breaks :))
    Please share any thoughts. Where do these things crack when they get hot? I never got it hot but I can say that the PO didn't.
    Regards,
    Nick
    • nick.cbr
      • 45
      Head was tweaked to the tune of .012" - looking for a head in the Minneapolis area.
      Nick
      • assblaster
        • Jul 2011
        • 75
        not looking forward to getting my head inspected
        • vandol
          • Jul 2009
          • 152
          just happened to me.. But coolant in the oil, Lots.
          325i
          • booboy
            • Dec 2009
            • 31
            Same situation here oil in the coolant reservoir.
            • lcoleman
              • Jan 2009
              • 331
              Oil in coolant is more common because the oiling system runs at a much higher pressure. Coolant in oil is a bad sign, IMO.
