just an update got a new relay from bmw and still no start, i have spark and fuel now
2.7 stroker build no start
When you did the engine swap did you also use the M20B25 AFM?. If you did and you have spark and correct rail fuel pressure when cranking, check (with a noid light) to see if the injectors are firing. If they are, the ignition wires could be out of order, the engine could be out of time (check the timing marks), or you could have intake leaks. If the injectors aren't firing, check C191.The car makes it possible, but the driver makes it happen.
I did the swap last wednesday. I am using m30 afm with 19# injectors. It was a bad relay since I grounded it out and also had my fuel feed and drain lines crossed. I still need to fix the exhaust leak coming from the manifold where I had to cut it. Also have a throttle body leak on the side so its leaking coolant, its a small pin hole size. And I need to tighten up my throttle cable seems a little lose in the beginning.
