Hey guys, my head went on my m20 engine... it sucks anyways i have just done all the service to the motor too timing belt, water pump, plugs you name it. My mechanic says that i need to swap out the motor but i'm pretty sure the block is not cracked or anything... It's been over heating a lot, rough idle in the mornings if i don't let it warm up, no heat, leaking coolant even with a new radiator, oil in the coolant...
Can someone give me a mechanic that knows e30s and is reasonable... Or even someone on the forum that will help i will compensate you. I located a used m20 motor to swap in but i think a new head would be fine honestly... Please let me know. Thanks
